FAQdaWorld
- Jul 22, 2010
- 14
Hey Folks
1987 Force 85hp Outboard
Problem : Fuel leak from the carb bowl area.
I have a fuel leak coming from what a manual describes to me as a 'jet' on the carb, but I believe its actually a venturi ( I could be wrong, I'm new to carbs! Maybe they are the same or I'm using the wrong terminology)
Here is a pic with circled in red where the leak is
I believe what is going on is that the float is stuck and the carb bowl is flooding with fuel thus spewing out gas anywhere it can. If this is the case can it be fixed without removing the entire carb assembly or can it be done on the engine (please god).
In the very likely situation that I'm totally off the wall wrong in whats going on, WHAT IS GOING on? and how to fix it please?
First to answer gets a theoretical cookie
Thanks,
-FAQ/Ryan
Thanks,
-FAQ/Ryan
