bjrrockwell
- Jun 18, 2011
- 49
I have a 1998 mariner offshore outboard with a new powerhead in 2000. Last night while on the water i got the beep beep beep of the low oil alarm at 1/2 throttle. i shut it down and checked the oil in the remote reservoir (just filled it) checked the line. Checked the reservoir in the engine (full). Started up idled fine, ran at an idle just fine in gear and even up to 1/4 throttle but soon as I pushed it more I got the low oil beep again. Came home tore oil pumpp apart, gears in like new shape so its not the nylon gear on the shaft (whew). took cap of and tripped float... that is working and is not the source of the alarm. This motor has been impeccably maintained. Put it on the muffs on the driveway and started it.. idled fine, no alarm. Started to raise idler arm and beeep beep beep, goes away as soon as I return to idle. As a side note my tach has gone off, its reading almost 3000 at idle which i know isn't right and pegs at 6000 at 1/2 throttle which again I know isn't right. that just developed this week as well. All marinas are booked till September for repairs. I understand I can premix but I don't want to 65 gallon tank I don't wanna deal with that headache especially with the fail safes in place to prevent a powerhead meltdown. Any ideas why my alarm goes at >2000 RPM but not at idle. Thank you ahead. If more information is needed please let mek now. I was supposed to hit the water tomorrow fishing but I'm afraid to until I pinpoint this problem. BTW blowing good smoke at idle so oil is getting in there. I'm at the point that I don't believe anyhting is wrong with the oil pump and this is a fault elsewhere.
