3.0 long block install
xlch
I have recentlly had my 3.0 long block rebuilt , i swapped all components
I get a little backfire but no start.
does anyone have any sugestions on what i should do?
Bt Doctur
Re: 3.0 long block install
If you dont have a manual , go to the Adults only section to get one.If you set the dist in properly at TDC and hooked up the plug wires , correctly set the push rods.it should be atleast "startable"
