Re: Electrical issues
as i found out recently there are several safety breakers/fuses involved with the electrical system on the four winns. Look for a red 50-60 button where the main battery line attaches to the engine. thats a breaker to cut electric power to the engine and main board.
these can be found in the manual, but press it and it should click, this is a reset of the breaker.
if this does not work check the fuse panel and if you have a reset 20 amp fuse next to the ignition switch.
also check to make sure the trans is in neutral and if you have a emergency cut off clip make sure that is attached correctly.
