missing at high rpms over 2500
AAvington
Hellow gentalmen i have a 1973 johnson outboard 115hp it idles fine it starts too misfire at about 2500 rpms
i have new plugs every eletrical component on the moter is only about 3 years old from stator,trigger,powerpack, engine harness and coils and the battery i recently have the carbs clead took apart and check.i think my stator might be going bad cant find any thing wrong with the carbs wondering what voltage should my stator put out at that rpm
Daviet
Re: missing at high rpms over 2500
Go to the CDI website and find your engine and use their troubleshooting section to see if you can find your problem.
