I just purchased a pontoon with a 200 hp merc outboard. It has power tilt and trim but no gauge. Have heard that most have the sender unit included just need to connect a gauge. Anyway to tell if that's true in my case?
Thanks.
There should be a little black puck on each side of the gimbal ring. Take a look and see if you have one or two. One will be the Trim Limit Sender and the other will be the Trim Indicator Sender. Here is a link that tells you more about them and shows what they look like.
http://www.sterndrives.com/replacing_trim_senders.html
