1961 Feathercraft Restoration w/pics.
hondarider188
So for those that were following me before on my last thread called Automotive paint here is my official restoration.
and this boat is a 1961 feathercraft cisco ll with a 1960 johnson seahorse 18hp on it, it also had a dealer installed full steering and dash with windsheild back in the day.
Yesterday evening me and my dad slid the boat off of the trailer and onto the grass then we drug it over to the saw horse rolled it onto its side then lifted it up(upside down) onto the saw horsed be then it was at least 5:30pm then i stayed out and sanded the entire hull most by hand and the good hand held disc sander then i finished masking off a few things then keps on sanding away taking away any loose paint that was chipped or cracked until 9:30pm so for a good 4 hours. Then this morning i sanded for another couple hours then got out the air hose and blew away all of the dust and anymore paint that wanted to come off. then i gave it a 50/50 vinegar and water bath then i realized i forgot to sand the stern and railing so i then got them done and gave it all another bath. then i waited for it to dry and i then got out the etching primer i only bought two cans for now and i got all fo the bare aluminum and then some covered with a good light dust. and i got this much done with just one can so i think i will break out othher can and just do some touch ups with it.
so heres what i got so far
hondarider188
Re: 1961 Feathercraft Restoration w/pics.
well sorry for the long wait i went out of town for the weekend. but on friday evening i got the left side of the hull painted with a rustoleum gloss white. i ended up buying a gallon of the stuff because i will be doing the trailer in the same white so a gallon will be plenty to do both the boat and trailer. so anyway on saturday morning i got up early and painted the right side of hte hull done with one thin coat, but the paint was mixed so thin that i had it running all down the boat so i had to dab the entire side of hte hull. but the night before it had been thin to but the gun just couldnt spray it on very good so i spent along time the night before getting it done. so i got the gun adjusted good for the thin paint and sprayed a second coat the the left side. i do wish though that i had used a filler primer on the hull it had some pretty deep scratches in the old paint and it would of made it looked alittle better. but sorry for those who were looking for a full restoration this is kind of a quickie and the designe of the boat it has no floor decking or foam filled seats so sorry for the lack of a full resto. but it did need a full paint job though. and if you want to read about bringing the engine back to life for it click herehttp://forums.iboats.com/showthread.php?t=487488
http://forums.iboats.com/showthread.php?t=497735
hondarider188
heres some pics. And any advice would be great.
hondarider188
well this morning i got a second coat on the right side and a third on the left so this afternoon i will put a third coat on the right side or does anyone think i need to or is two plenty i jsut thought i would so it would be even on each side? and i sprayed a coat on the trailer with the same rustoleum gloss white. im not posting any pics on this for you cant tell a big difference enless your here in person.
Woodonglass
R U using the hardener in the Paint?? If not your cure time before gettin her wet is two weeks minimum!;)
hondarider188
no i didnt use a hardner i had a hard time finding one so i decided to just go ahead and paint. but thanks for the heads up on the two weeks i was hoping to get it done and take it out this weekend. but why do you have to wait so long? on the can it says that 24 hours is a full cure so wouldnt i be good to go then.
hondarider188
and i jsut got done recarpeting the trailer and i painted the rollers then greased them all and put them back on and i replaced the bow roller. now all i have left to do is paint the the trailing boards black.
hondarider188
well last night i got the boat flipped right side up then i backed the trailer right up to it then tipped it back and pushed it under then i pushed thes boat as far up until the winch would reach the i just winched it right on. now i just need to paint the inside walls and benches. would do you guys think about the bow do you think i should put plywood in it like it was then carpet it and make a hatch or put in a pedistal seat or even just leave it empty? and still wonder about the cure time woodonglass mentioned and if the can says full cure in 24hrs wouldnt i be good to go then.
hondarider188
any ideas on bow?
Woodonglass
I am speaking from experience, and from other iBoaters experiences. If you don't want it to peel off I would wait. It's up to you.
hondarider188
k thanks for the advice i dont think it wil be anytime to soon anyway cause i still need to paint the inside and get it prepped and ready. but do you have any ideas about the bow. like i said before it had a peice of plywood in there before covering the bottom of the deck. do you think i should just replace it like it was or make a hatch for it or even put in a pedestal seat.
Sander
Nice backyard!
hondarider188
thanks. got any thoughts on the bow?
hondarider188
well i have been getting the inside of the boat all prepped and ready to paint but still havealot of work to do. and i will post some pics soon of the boat back on the trailer.
hondarider188
well sorry been some stormy wheather so not much time to work on thee boat in the evening and school started so cant in the morning anymore but i still did get some of the inside prepped. i got all of the floor covered with newspaper and the holes in the bow filled and sanded useing quicksteel i got it at checker for only like $3 and it fully cured in 24 hours. so then i got the bow and front bench primed with 50/50 vinegar and water then used and etching primer then the side rims and stern primed so now all thats left is the inside walls then to paint. sorry for lack of pics will try to get some soon.
hondarider188
well i finally got the bow and interior painted along with the rim. and it turned out absolutly awsome and i will try to get some pics tommorrow and i have just been doing some touch up work on the paint lines. and does anybody know a good way to clean the windsheild it is made of pexiglass and tonight i tried a small about of a car rubbing compound in the corner so if it cleans it up good and stays i will go ahead and use it but if anyone has a better solution let me know.
hondarider188
k i finnaly got it all said and done with the entire boat put back together except the bow light. and i got some pics of it all done. and in the pic i didnt have the numbers on the starboard side yet but i got them on after pics. so what do you think?
johnmorgan
cool boat I really like the paint, the old school motor. that boat must fly.
hondarider188
thanks for the input but it dont fly like you think it would i dont know if the boat is just heavy or if the engine still needs a little more work but i dont think i am getting above 10 miles per' hour. but i do know the boat weighs around 169-180 pounds not to mention all of the added gear and two people.
kfa4303
Banned
looks great hondarider !!!!! I think you should probably get more than 10 mph out of her, assuming everything is running properly :/ I have a 20 hp on a similar sized (14') aluminum boat, and I found that I had to to trim the motor up to the 2nd notch from the bottom position to get optimal performance. I think it is/was because the cavitation plate on the motor was too deep into the water. Try doing the same to yours and see if it helps. I'm even debating getting a jack plate of some type to raise the motor even higher so that the cav plate is even or slightly above the keel. Congrats again on the new toy.
