i've got to spend most of the summer working on my 1996 larson 260 cabrio, with bravo 3, instead of playing.
enough of the whining. this spring i lost the shutter valves and dumped water on the pistons. as soon as i
found out what had happened i changed the oil, and put in some cheap 30 weight. after the repairs and a
short run on the muffs to check the work, i changed the oil again (no sign of overfull), but still signs of water.
preparing for what will be almost my last trip for the year i changed the oil again, using good 20-50 weight oil.
no sign of overfull but still kind of a medium coffee color to the oil. i realize pumping out through the dipstick
will not get every little bit, but i really hate to consider the alternatives. how long should i see signs of water
in the oil? and can this small amount cause terrible damage to the engine?
altlrumy
altlrumy
