- Jul 23, 2011
- 52,851
have a few button studs that are loose. go to pull them out to put epoxy in the holes and turns out there is silicone holding them in. Called the prior owner, he had the canvas done at Sh*#@#$% Marine because he didnt want to wreck anything (name withheld to be nice).
Sure enough in the folder of receipts is a copy of the job
now there are #8 and #10 button studs in the various holes (it looks like the #10's were in attempt to fill the hole). I can not get to the back side to put a screw/nut combination due to the floatation foam.
does anyone make a #12 button stud?
I have some 5 minute epoxy that I was intending to use to fix the one or two loose ones , however I may end up doing a whole bunch of them.
