vintageglass
- Nov 22, 2010
- 80
The above motor is on a used boat a neighbor bought, it came from an estate sale and had been sitting for about 6 months. It starts right up and will move along fine so long as you apply power slowly and don't go over about 3/4 throttle. I had the carbs rebuilt at a dealer, a new water pump and fuel pump installed at the same time, and it had the water separator filter and all of the fuel hoses replaced. The same dealer also replaced the coils and plugs, as well as the switch box. There is no change. He's now into this motor for over $2200 and it still won't move the boat as it should. It's also got a brand new SS prop on it which was recommended to eliminate the possibility of it being a spun hub.
The dealer says the motor is tired?
I checked the compression and it's got 90 psi on all 6 cylinders?
What should I be seeing out of one of these? One private shop tells me he thinks I should be seeing closer to 140psi?
The motor don't knock, it starts right up and idles fine and will move the boat along to about 20 mph without any issues but any more than that and it bogs down or stumbles real bad. It will gain engine RPM only if you ever so slowly apply throttle.
It runs fine on a hose and ears, but won't run right on the water.
The boat is light, maybe 1600 lbs or so afloat and not water logged or overloaded.
The boat is set up the way it was from the dealer when new according to the son of the former owner, he said it ran fine when he was last on it years ago, but hadn't been on it in recent years. The boat has a stack of repair and maintenance history all from the same dealer. The prop installed was also the same pitch that was on it, and the same pitch that was installed on it in previous repairs over the years.
I was thinking it was a carb issue till I saw the compression readings?
That and the fact that I can nurse this thing up to speed and gradually apply power, it just won't tolerate being pushed very hard without stumbling.
When it stumbles, you have to return to idle and start over trying to accelerate.
