Re: nida-core or seacast ?
the shavings were somewhat dark, i had the boat in the water a few weeks ago, all was fine and got the mercury beep beep oil alarm, that turned out to be the sensor in the bottom of the oil tank came loose, bought a new oil tank (one that's mounted on the powerhead)and its sensor, replaced that, replaced the oil warning module as i heard that goes bad often, purged the air from the oil bleed screw and outlet of oil pump hooking up the 50:1 oil/gas mix can, replaced the thermostat, poppet valve and gasket, replaced the temp sending unit , water pump, and little gas filter about a inch long thats behind the oil tank while i was there (bypass gas filter something or other) . Anyway, i wanna get all forethcoming problems resolved so i can enjoy going boating without running into a older boats problems and heard it's just a matter of time before the transom is shot and i dont wanna lose the motor after doing all the work on it is all, is a great motor and i want it to last, as for the boat i imagine if that goes down i assume i can always have it raised and repaired for a lot less $ than the motor.
