1985 Mercruiser 3.0L M# MCM 140, SN: 6922598, with Mercarb.
My throttle adjustment has a little slack in it. When I pull the throttle back to idle the idle is too high. If I push on the connecting arm from the carburetor to the throttle cable it will move almost ? inch. Then the idle will be good.
How do I tighten up the slack? Should there be a return spring? The book says to remove the return spring before removing the connecting arm when disassibaling but my carburetor does not have an external return spring.
Thanks,
Thanks,
