fuses
heels
don,t have guide bookfor 1987 capri and can,t find fuse panel to hook up hummingbird fish finder.Anyone know where it is?
Kurt V
Re: fuses
If it is the same as an '89 Capri, it is under the dash on the driver's side.
Ramblin'man
Re: fuses
My '95 is the same. It is under the dash on the driver side. It is tucked in tight too. The only way to see and access it is to lay on my back on the floor and use a flash light unless you want more ease to work on it, take the lower panel off or loosen the top two brackets to allow the panel to drop down
