1995 gtx seadoo will not start after it has been running
chriscraft95
My 1995 gtx seadoo will not start after it has been running. After I run the seadoo for about 15 and 20 min I shut it down and it will not start. Let it sit for a hour and it will start or if I take it out of the water it will start right up. Sometimes if I keep on turning it over and over and hold the gas down it will go. Please help I change the oil filter, gas filter. Plugs and also had the battery check and it's ok.
Leedanger
Re: 1995 gtx seadoo will not start after it has been running
I just learned this so I imagine you may be in the same boat. Your idle should be set to approx 3000 rpm out of the water and 1500 in so check that. Chances are though you have a gas issue. The fuel selector (res, off, and on) can and do get plugged and almost certain the carbs need to be rebuild or at min cleaned for that year. Supposedly that "fuel filter" is actually a water/fuel separator so I believe you HAVE to use a new one from the OEM vs one from parts store.
