I have a 1994 24' pontoon with a 1994 Johnson 115 hp motor that I just purchased & hauled home. I live in Wyoming & 6300' higher in elevation from where I purchased the pontoon. On my first trip out, I was only able to go about 15 mph & seemed to be lacking the "umph". Spoke with my local dealer & he said that I should start with re-proping the motor with less pitch. Just wanted to get some extra information from the fellow forum members before I do this. Mostly use the pontoon for fishing & cruising, but also like to pull the kids around on a tube too.
I believe the motor has a 16 pitch propeller now (will have to pull it to varify), should I reduce that down to 13 pitch?
Should I get a 3 or 4 blade prop? What are the advantages/disadvantages of each?
What are the differences between steel & aluminum props? Any advantages/disadvanges of each?
