I recently bought a 1989 Teka cuddy 20' with AQ 231a in it. The seller told me the engine was froze after sitting 3 years, he informed me that he sprayed PB Blaster into cylinders when disovering sieze. The engine will turn over now, so I took to local repair to figure out why there is no spark. After doing a compression test he said I have 80 lbs on 2 center cylinders and 170 lbs on the driver side cylinders. Question is should I get repaired or just by a new rebuild. I can get fresh block with heads for $1300. Not sure what a rebuild cost will cost for that. He told me he could rip the engine apart to see why the low compression. But at $45 an hour that could get costly. The boat is in great shape. Or should I cut the lsses and let someone else deal with it. Wuld the boat run the way it is, and just be a dog?
Thanks for your opinions
