I have run into an apparently common problem. My voltage regulator went out on my 1981 75 hp chrysler. The replacement is a small black square with four prongs and a hole in the middle to mount it. Now that ive put this on I also put on a volt meter by the way. I get 14 to 17 volts!!! This part is recomended by this web site!! through my own investigation ive found this is a rectifier not a regulator/rectifier. What I need is something to change ac to dc current (rectifier) and something to regulate how much voltage the stator puts out (voltage regulator). The little black box only perfporms one of the functions. it makes it dc current so powerful my battery is going to explode. I will be writing Iboats about this. Just so everyone knows. DO NOT BUY THE LITTLE BLACK RECTIFIER. ITS JUNK. I found a universal regulator/rectifier for 55.00 on another website. Its for a snowmobile. I found other people had this same problem. Their telling
people to put a part on your boat that will make your battery explode!!! NOT COOL
