chuckfromaustin
- Jul 6, 2002
- 7
I think the drive shaft isn't mating up to whatever fitting exists up under the motor, so the lower unit won't slide up tight to the outer housing. Can you say what sort of connection is made up there? Does the drive shaft slide into some keyed opening? I can't see in there and I can't tell by the feel of the lower unit hitting metal up under the motor. pretty frustrating,<br /><br />thanks!<br /><br />chuck
