Crewchief18
- Aug 8, 2011
- 1
I have a 1986 Johnson 150 when it's in neutral it revs fine the whole way to wot but with the prop engaged it runs fine to little past half throttle then if you go further it starts to lay over and stall out. I did the wot timing with the plugs out method. It does make it to the advance stop and the timing is correct at that point but if you go further with the throttle is when it happens. The stator and timer base are new and the power head has only about 5 hours on it. Thanks in advance for any help.
