iliketrout
- Apr 7, 2010
- 15
Did a search and came up with some relevant threads but none that specifically address my concerns. So here goes. Sorry if I'm a little long winded but I wanted to present all facts.
Looking for some input on my 1981 Evinrude 15 hp outboard. I recently purchased this motor and 12' aluminum. Here's the problem.
First time I took the boat and motor out, I started up the motor, and left the dock area. It went to wide open throttle no problem, motor made good RPM's (based on sound) and got the boat up on plane, and got to about 16.5+ MPH (GPS). However, I noticed that the longer the motor ran (starting after about 3-5 mins), it would begin to bog down, lose RPM's, and I would eventually lose speed down to about 12.5 mph and barely keep it on plane. After the bogging down began, if I let off the throttle, came to a stop, and cracked it wide open again immediately, there was a noticeable lack of power and it struggled to get up on plane.
I then shut the motor down, let it sit for a few minutes and then fired it up. Again, up on plane immediately, ran good, got back up to 16.5+ MPH, but eventually began to bog down. Then, after bogging down, it regained some power (without shutting down), I got back up to about 14.5 mph, and then eventually back down to 12.5 mph. It never got worse than this. I shut down a second time and waited for 5-10 mins, then fired up and again back to full power for the last 5 mins of the trip back to the dock at the end of the day.
More info:
Fuel was fresh and fresh oil was mixed at 50:1
Water pump was running, can touch the head for 3-4 seconds easily when the bogging occurs. Overheating likely not the cause IMO.
When the motor was running and bogging down, I squeezed the ball on the fuel hose and this did nothing. The ball does not completely firm up like I'd expect but does hold pressure. Tank is vented and was vented for the entire time.
The motor starts right away, runs very well at low throttle, no audible misses, no sputtering. When bogging down, it simply sounds/feels like someone was gradually closing the throttle, it does not sound like the motor is missing at all.
The flywheel is not perfectly tight. When the motor is cold, at a certain point in the flywheel rotation, It wiggles very, very slightly. Not measurable. Not at all points in the flywheel rotation. No oil under the flywheel, if a bearing is going, it hasn't leaked yet.
The prop is not spun.
Had two trips like stated above. So I did the following:
Re-built the carb with genuine OMC kit. Noticed that the welch plug had a leak and there was thick black reside all around the plug and it had dripped down the side of the carb body. Replaced and re-sealed welch plug.
Replaced spark plugs
Checked compression - both cylinders are 110-115 PSI cold. Did not check when motor was hot out on the lake. Assuming that if I'm getting great compression cold, it will be good warm. Maybe this is bad thinking.
Ran the motor in a dark area. No noticeable errant sparking.
These repairs were done and I took it out yesterday. The motor started a little easier, I generated a little more power (got up to 17.8 MPH but this was with the wind) and 17.0 MPH into the wind. Seemed to last slightly longer with full power, but not a huge difference. The one thing I tested that I did not test previously was: when the motor was generating full power, I cut the throttle down to idle. Then I opened it back to full throttle and immediately did not have full power. There was no long bleed off of power. This may or may not be new, but it was the first time I tried this. I think this is a good clue, but I can't think what to do next.
I was going to do the fuel pump but I received the wrong pump kit, new one is on the way. At the same time I'll do the fuel hoses with ethanol resistant ones. My last suspects are:
1) Carb - is there an adjustment I can make?
2) Fuel Pump? Going to put the new kit in and try again, but figured I'd post here to see if there were any other ideas in the meantime.
3) Thermostat problem?
4) Spark - could this be a power pack heating up and slowly failing? I don't think it is, as I said when it is losing power, it is not missing, it just sounds like the throttle is gradually closing.
5) Wobbly fly wheel - could this be causing some binding when the motor heats up? I think it's doubtful - due to the immediate loss of power described just above, and due to the fact that the power came back on the first trip without me letting the motor idle or shut down.
If you've made it this far, thanks for reading!! Looking for any and all ideas. I was reading another thread where there was a motor with similar symptoms and it ended up being a head gasket. Would have never guessed that. Any and all ideas are appreciated.
Thanks!
More info:
Thanks!
