Hello all and thanks in advance for your assistance.
I have a 1989 Rinker Captiva 206 Bowrider best guess on GVW is 3300#
Engine: 5.7L 4bbl carb guessing HP around 250, Recommended revs at WOT 4200 - 4600 (I think)
Outdrive: Alpha one, gen one I think it has a 1.50 gear ratio (but am not positive)
Came with a three blade MERC 14x21 aluminum prop (great condition)
Tested at typical load: WOT - 4575rpm GPS speed - 49mph
I wanted to get a little better pulling and midrange economy so I did some research and tried out the Piranha four blade 20 pitch propeller.
Tested at typical load: WOT 4100rpm GPS speed 44mph
Seemed to pull just a little better and was certainly faster to plane but due to under reving (and what seemed to be very excessive fuel usage), I sent to get the 18p blades
Tested at typical load: WOT 5100 GPS speed 37mph
Now I am not exacly sure what happened here. Every test was done trimmed out. I tried several times with each propeller very close results each time. What the heck?
More importantly, what now? My thought is to get a solas four blade aluminum 21 pitch. Would this give me better pulling and mid range without under reving? What about just getting a 21p three bladed solas for a backup?
If I went stainless, what should I go with? 3 or four blade? what pitch?
Thanks again for your assistance.
