Re: water bellow
Im thnkn your a little confused... 3 bellows, none are water bellows . The top biggest one is the u-joint bellow, keeps u-joints and gimble bearing dry and prevents boat from sinking. Under that is the exhaust bellow. Engine cooling water and exhaust are discharged from the engine thru this. Im thinkn this is what u r referring to when u speak of water bellows, as it does have water in it. Its the only bellow that should. The small one next to the exhaust bellow is the shift cable bellow, keeps water out of the boat as well. The water supply hose that supplies cooling water from the drive to the engine is kinda tucked up in the drive , its probably a 3/4 or 5/8 in black hose, it goes to a connector on the transom... Plz elaborate a little more..
