In chasing down a problem not getting to WOT RPMs on a '99 Evinrude 50 4-stroke, it first sounded like he neutral switch was stuck. Checked everything out with a ohm meter and it was fine.
Following the manual, I checked all of the coil resistance measurements all the way back to the ECM and all were fine, thinking it was a bad coil. Just trying different things, and I unplugged the coil on Cyl#3 and the motor will start and idle with no change in the idle, but if #1 or #2 are unplugged, the motor will die if running, or will not start so I figured that the #3 coil is bad BUT, when I swapped the #1 and #3 coil, it did the same thing so it can't be the #3 coil. It looks like it can run/start on #1 and #2 but not #2-#3 or #1-#3.
Checked the wiring back to the ECM and there is continuity so it is not a wiring issue.
Any ideas?
Any ideas?
