I was in reverse when i hit something in the water and was wondering if damage was done to the gears? She shifts fine in forward and reverse and was just wondering if anything would the drive gears be ok?
james you posted this twice in different ways <br /><br />if you were going slow in reverse and the shaft is NOT bent then you should be ok<br /><br /><br />the real key is to check the shaft with a dial indactaor for run out to be sure its ok<br /><br />tommays
