I have a 2003 Nissan NS5B 2-stroke. Symptom is that after starting, the carb overflows fuel and the engine chokes out.
I have replaced the float valve and am confident it is installed correctly. After removing the carb, when blowing through the fuel inlet on the pump, air passes through the carb both right side up (float valve open) and upside down (float valve closed). The float is level when turning carb upside down, and the float valve appears fully closed, suggesting it is properly adjusted.
It appears that it's something simple, but I'm stumped.
Would appreciate suggestions on the fix.
Many thanks,
Many thanks,
