I guess ill list everything already done and give a short history first. it is the boat in my signature. It ran great all last season after the carb replacement with a new 1609 eldelbrok. i unwinterized it this year, new oil in the drive and motor along with filter, and water seperator. replaced spark plugs, wires, checked cap and rotor.
during our first outing this year july 16th, boat ran great for over an hour, then started surging badly and stalled. tried to restart imediately, would not re fire. waited about 10 after checking over the engine for obvious issues. started right up like nothing happened. idled great put it in gear and away we went. within 2 minutes surged and dies again. same senario played out all the way to the dock. took the boat home, put the ears on and went to diagnose. drained water seperator, no water in oil. drained all fuel out of the tank checked vents and hoses, refilled with fresh fuel. took it out again, about 15-20 minutes into this trip it started surging and dieing. again back on the trailer and home, replaced thunderbolt iv coil, and distributor sensor. again same problem, this time after 5-10 minutes. so after all of this i have searched and found from a local marina near me, im going to take the thunderbolt iv system off tomorrow and try the new Pertronix electronic ignition kit. Also there is no water in the oil checked that also. thinking possible head gasket.
my reason for posting is if anyone has seen this problem or knows of other items i need to check please let me know. thank you in advance.
