I recently stripped a timing belt when slowing down from about 4000 rpm to idle and I believe that this caused a hydro-lock. Pulled plugs, emptied cylinders of salt water, lubed the cylinders, replaced belt and re-did timing as well as cleaned carb and intake manifold of water. I managed to re-start the engine but cannot get it to idle. I have cleaned all the jets in the carb and I am convinced it is a carb problem but maybe I am missing something here. Any suggestions would be much appreciated.
Thanks
Thanks
