joshmuhlstej
- Aug 7, 2011
- 1
It starts fine, first pull and will run perfectly for about a min full throttle then it just starts to bog down and it seems like its loading up and bogging down. I can run it on about quarter throttle and it will run fine, but once I try to give the full throttle it just bogs down. It never fully dies though once I let off to half throttle. I've put new gas in with some sea foam and changed the fuel lines, but that wasn't the trick. One thing I have noticed is that I don't think the throttle plate is opening up as much as it should, but I'm not familiar with outboard motors at all. Any help would be greatly appreciated.
Thanks, Josh
Thanks, Josh
