My 48 johnson starts to surge after running for a few minutes. I have disassembled and cleaned the the carbs, checked the fuel pump screen, replaced the fuel hose connectors. It will try to run right if I keep pushing on the key (prime pump). Sometimes it will start to run right after running at half throttle. Att the hose connections are tight. What ar the symtoms of a bad fuel pump?
