I have a '79 70 Evinrude that I'm getting water into the lower unit oil. It has been really milky the last two times I have drained it. I made a pressure tester and pressure tested the lower unit to 15 psi and it held that pressure for 30 mins. I also tested with vacuum and it held a vacuum for 30 mins. Has anyone else had this happen to them? The drain and fill plugs have new gaskets. I looked at the propshaft and when I'm looking at the seal I can see the spring that is supposed to keep the rubber tight to the shaft. Any ideas? Could that seal be letting water in or letting oil out when the prop is turning?
