lower unit lube
tx1961whaler
Re: lower unit lube
85-90W marine gear oil. Less than 1 quart required. Squeeze in through the bottom drain hole until it squirts out the top drain hole. Don't take out the phillips screw.
Daviet
Re: lower unit lube
And use new seal washers on the drain/vent screws.
nwcove
Re: lower unit lube
just a point of interest..... i always fill my small motors with them vertical on a stand, but recently watched a friend fill his gearcase (from the bottom hole) with the motor laying on its side. told him ididnt think it was a good idea to do it that way, because you can loose the expansion space, and blow seals out. is my old brain having a moment???? lol :eek:
dazk14
Ensign
Re: lower unit lube
There are a few motors that were filled that way, but 99.9% odds he doesn't have one... and yes, the expansion space is needed.
nwcove
Re: lower unit lube
guess i should have mentioned .....it appeared to be a late 80's evinrude 9.9.
dazk14
Ensign
Re: lower unit lube
Your friend fits squarely into the 99.9% and you are 100% correct...
He may have some air pockets in there, but unless he's refilling with a specific ounce quantity(can be done), who in ell' knows what's in there.
The 9.9's of that vintage take 9 ounces from a dry start.
nwcove
Re: lower unit lube
:facepalm:
The FULLY drained refill capacity of the 1973 6hp is 9 ounces. All other info has been posted.
thats great daz, nice to see you closed the thread ! hopefully others have all the info / opinions they need to properly service their gearcase! :facepalm:
