mybluecreation
- Aug 7, 2011
- 4
Hi, i'm having a grounding issue with the electrical system on my 88 johnson 60hp 3 cyl outboard i bought the motor recently and mounted it to a 18 ft aluminum starcraft i saved from the scrap yard , i never saw the motor hooked up but had it running briefly until the vro warning went off and it shut down i recently unhooked the vro and ran it yesterday for a minute , but my issue is the ground... Im running it with 2 batteries on a selector switch, grounded the batteries to the frame on the inside of the transom and ran a 16 g jumper from the batteries to the ground on the power head and it started right up but the jumper wire i used for the ground wire burned up, and i know i did somthing very wrong like i said i never saw it hooked up saw im just taking stabs in the dark , i went over the manual a hundred times and it tells very little about grounding the batteries accept to ground to the power head , i need to know the gauge wire to use and where and how to ground it ,any help would be greatly appriciated ...Thanks
