kneedeepbc
- Aug 6, 2011
- 3
I have just purchased a '90 Sea Ray Sport I/O 180. Unit has no engine, outdrive, trim pump or rams. A 4.3 V6 came out of it. It does have gimbal housing with bellows, exhaust y-pipe with boots & elbows, complete gimbal transom plate with engine mounts. As I look for engines, if something other than a 4.3 is installed, will alterations to the existing setup be necessary, thus incurring more installation expense? Also, are some engines models historically more prone to problems than others? Does anyone have an opinion as to the cost of operating a 6 cylinder vs an 8 cylinder? Also, what is the least amount and the upper limit of hp that should be considered? Thanks in advance. Hopefully some day I'll be on the answer giving side!!!!!
