jgresham75
- Aug 19, 2008
- 70
Have a 99 5.0GL. I rebuilt the engine. I am a car guy so when it came to the heads, I was used to torque-ing the bolts. However, Volvo uses torgue with angle. (Please hold the "you should have done it right the first time". I am paying for my mistake).
I torgued and then estimated the angles.:facepalm: When I finished all the bolts, some were still loose. I went back and tried to tighten them. This meant that I did not torgue correctly.
I went on to finish motor, install and take for a test run (only for about 30 minutes total). It ran pretty good but only about 90%. Got back to fine tune and found a little bit of water leaking down the oustide of the block from between the block and head gasket. Obviously I didn't tighten the head bolts properly. Now here is my questions for any experts.
1. Could I go back and retighten in the proper sequence using an angle meter and get sufficient results? This is obviously the easiest choice.
2. If not, should I replace the bolts when replacing the gasket? The bolts are new and were just replaced with this rebuild.
Thanks for your help.
