bang4dabuck
- May 24, 2009
- 296
Middle age crisis. Trying to become mechanical. Synching up. Am I trying to find a consistent point or am I trying to get an average of TDC ? I am not forking over the money for that piston stop tool but have tried the NGK BR9ES long reach spark plug which when put in all the way stops the piston BEFORE TDC as compared to my other method of measuring which is with a pencil, erasure end first. So am I just looking for an AVERAGE spot at some common point of piston head or am I trying to get TDC ? I could see maybe when piston is stopped by spark plug I could loosen plug out a little then move flywheel a little and so on until I figure out where TDC is. The pencil method is a bit rough because it is all by eye. So what should I be doing ? How often when you mark it twice they are virtually the same spot ?
