2008 40hp four stroke jet draining the fuel system
travisbiddy
just bought a new boat with a merc 40 four stroke jet went out on the river it fired right up and took off but after a feww hundred yards up the river it bogged out and when i tried tostart it back up it would run for a few seconds and shut back off ..im thinking it was bad fuel from last year even know it had stabil added i have no idea how to drain the the fuel system...i already went and got new gas but it does the same thing any suggestions please help!!!!!
CharlieB
Re: 2008 40hp four stroke jet draining the fuel system
Disconnect the fuel hose to the carbs, point it into a suitable container. Pull the Lanyard so the motor will not start, now crank for 5 - 10 seconds and observe the fuel stream, is it a stroing pulsed flow?
