My steering is very stiff. I have disconnect the steering cable from the outboard and the outboard pivots smootly and with ease. I also disconnected the steering cable at the steering column. The steering wheel spins quick and smoothly. The cable must need cleaning and regreasing. The cable is a Morse brand, rack and pinion style. The geared end has a long flat rectangular shaped enclosure that the cable and geared end slide back and forth. It appears the cable can be unscewed inside the enclosure, but I can't get a wrench or nut driver on the nut. The enclosure is rivoted, so I can't seperate the two halves of the enclosure. I could always drill out the rivot and install a nut and bolt when reassembling. Hopefully there is a better way. Thanks in advance for any help or advice. I don't know how old the cable is, unfortunately. I'm sure that it must be at least 15 years old, maybe more. The cable has been fully removed from the boat.
