I have a 1971 100hp that stopped running. There is no spark when cranking except occassionally a single spark when turning the key off after cranking. Am I correct in thinking that would indicate the ignition coil is ok and by process of elimination the amplifier is at fault? Is anything else a likely cause? I will try the light bulb test for the amplifier when I have a chance. Points are set correctly.
Where is a good source for a replacement amp if required?
Thanks Ken
Thanks Ken
