Its expensive but would look cool...
what do you guys think?
Take a carbon fiber hood for a car.....if you paint then it looks the same as any other hood, buy weight is much lighter..and stronger.
I've never used carbon fiber for a boat..so correct me if I'm wrong....
CW
Its obvious from most of the responses they have never seen, rode in, or know what a Contender boat is. Keep in mind 99% of the people on this forum run around in lakes on an eggshell with plywood stringers with a foot chop on a bad day. They don't know what a beating a FL salt water boat takes on a normal day. .
Its obvious from most of the responses they have never seen, rode in, or know what a Contender boat is. Keep in mind 99% of the people on this forum run around in lakes on an eggshell with plywood stringers with a foot chop on a bad day. They don't know what a beating a FL salt water boat takes on a normal day. We came in to make weigh-in for a tournament in 28 Contender with 6 ft following sea running 40plus knts into Clearwater pass. And no they aint rollers. This is no back Gulf crap. And never once even thought about a problem. We did break a trim tab.
I think that would be a great idea. Don't tell anyone that we can add texture to our paint.
to...add......
why dont you build the instrument cluster out of carbon fiber?......you get the look.....and it is in a much better place than the deck?
