boat_help_please
- Aug 4, 2011
- 4
Hi again,
So in trying to fix my water leaking into the cylinders, I removed the Head and the head gasket looked fine. On the outer cover of the exhaust there is the pee tube attached to a threaded hole as you can see here.
However, the inner cover also has a threaded hole which the pee tubes thread can not reach.
Does that tube need to thread into the inner cover also? It wouldn't make sense to me as that is the exahust, but why the threaded hole? Thanks again for all of your help! It is greatly appreciated!!
