rbollinger
- Aug 3, 2011
- 3
Hello,
I recently purchased a 4HP Lightwin as a kicker for my sailboat. First time I was out, things ran great, no problems. The second time I was out things were going great until I was motoring into the boat launch. As I was heading in the motor revved up very high, so I immediately cut the throttle. I started the engine back up, and it sounded fine, but when I looked down at the propeller I realized it was no longer moving. I've been stalking this forum a bit to figure out where to start. So far I've removed the propeller and checked the drive pin and the hub. The drive pin is still one solid piece and is definitely not the problem. The clutch still has a nice tight fit with the hub, and the hub is stuck solidly in the propeller. So the next thing I tried was spinning the flywheel by hand. When I do this there is no movement on the prop shaft (there should be right). My best guess is that the problem exists in the prop shaft, pinion, or drive shaft. So I was planning on getting a service manual and taking the Lower Unit apart. Am I on the right track or am I missing something obvious? If it makes any difference the flywheel spins easily.
Thanks,
Jake
Thanks,
Jake
