Is it normal to have gas running out of carbs when the motor is tilted all the way up? Last time I had it on the lake it died. I found a hose that was disconnected so I reconnected it and it started
fine in driveway. In the process I tilted up the engine and swapped out impeller. Gas started pouring out of the carbs for about 30 seconds.
