boat_help_please
- Aug 4, 2011
- 4
Hi everyone,
I found this forum and see some great post, so I thought maybe someone can help me out!
I have a 1974 50HP Evinrude 2 stroke. I have water getting in cylinder 1. Compression test are fine and water is peeing well. I have cleaned the carbs and changed the fuel pump. I took the head off and there is a bit of rust in the cylinder, however the head gasket looks fine and no rust around the ring. It starts a bit rough and then runs ok, but there is very low power under load and will die at idle speed and when I put it into gear unless i keep it revved up.
Thank you in advance for the quick responses as I am trying to take it out this weekend!!!
