Still trying to figure out why the prop shaft pulled out, and didn't pull the entire lower bearing housing assembly with it...I'm not sure if the tip of this shaft is broken off, or if it supposed to be a notch only. Can't find any pics of it on the web, and the pics in the diagrams don't really show the tip. Should it be enclosed, and only a hole in the side for the pin from the clutch dog to go through? If thats the case, and I need a new one I can't seem to locate one anywhere. Anyways, heres the photo
