OK SO I HAVE THE 1985 85 FORCE OUTBOARD WITH A 3 WIRE TILT MOTOR ON IT. MY QUESTION IS THIS. I FOUND A SWITCH AT BASS PRO LAST NIGHT THAT IS RATED FOR 50AMPS AND ACCORDING TO THE GUY IN THE REPAIR AREA IT SHOULD WORK JUST FIND ON MY SETUP. MY ONLY CONCERN IS THE WIRING GOING INTO THIS NEW SWITCH IS ABOUT HALF THE DIAMETER OF THE WIRING ON THE OLD SYSTEM. I CAN SPLICE THEM IN NO PROBLEM AND IT IS ONLY ABOUT A FOOT FROM THE MOTOR. DO YOU GUYS THINK THAT IT WILL BE OK? LIKE I SAID ACCORDING TO THE BOX IT IS RATED AT 50AMPS, AND FROM WHAT I HAVE READ IT IS A 20 AMP CIRCUIT. ALSO I DO UNDERSTAND THAT THE WIRES ARE AS THICK AS THEY ARE TO HELP THE CURRENT BE ABLE TO REACH THE SWITCH IN THE DASH TO THE MOTOR WITH MINIMAL CURRENT DROP. THIS IS THE SWITCH I FOUND I FOUND IT AT BASS PRO BUT CAN ONLY FIND IT ONLINE AT ACADEMYS WEBSITE.
http://www.academy.com/webapp/wcs/stores/servlet/Product_10151_10051_20051_-1?Ntt=TRANSOM&Ntk=All
