45calmuzzleloader
- Jul 5, 2010
- 12
I have a 1950 kg7 I'm working on. Engine has great compression 130psi, new coils new condensers, great spark. Motor starts easy and idles pretty good. Slight miss at higher rpm's while running in a barrel. Bottom spark plug is super clean, top plug looks right. I have already replaced both exhaust baffle gaskets. Researching this problem tells me my lower crank seal may be bad. How hard is it to replace the lower crank seal? Thanks.
