90 johnson 1984 throttle warmup lever
g8ts
VRO 90 Johnson 1984
OMC controler
Throttle lever not working, will not throttle up or down, will not shift out of neutral.
Was stuck on the lake so I took the OMC controller box apart and was able to shift into drive and get off the lake.
Manually with OMC box open throttle worked fine by pulling and pushing on the cable. In upper Wisconsin on vacation so all help would be great to get back out on the water...
Engine was running fine, switched tanks and then could not get it back into drive.
Thanks,
boobie
Re: 90 johnson 1984 throttle warmup lever
If you're in upper Wisconsin I'd find a dealer and take it into him. You may have some broken parts. I'm from that part of the country and there's a lot of good dlrs around.
