97 yamaha 200 SS knocks and ticks at idle when i rev it up past 1500 it goes away. Did compression test and all is within 100-112. Check water pump and made sure i pulled up on shaft this time and put wave washers in correctly. I did start motor with lower unit off just for a second and the knock still remains. Engines are regularly maintained. Did notice this motor burns a little more oil than its counter part. please help rodbolt and other yamaha guys.
