204 Escape
Ensign
- Nov 17, 2007
- 909
OR, at least block the sun from hitting them !!! It's 110* here today. The excessive heat is sure hard on the tires !!! (Just my $0.02 worth) !!
Hey, guy74. We aren't too far apart !!!!!! ;-) I live in Humboldt !!!!! Haven't made it to Farlington this year.
If its so good for your tire, are you spraying the side that faces inside too? Since you are covering your tire anyway, both sides are out of the sun.^^^^^ Thats like saying waxing your car does absolutely nothing. You mean to tell me that if you take 2 of the same brand new name brand tires and throw them out in the sun at the same time - 1 has no protection - 1 has spray protection, they will end up dry rotting the same amount during the same time?
You guys actually think a tire sitting in 100 degrees temperature is actually getting hotter than one rolling down the highway on even an 80 degree day along with the heat from your brakes dissipated through the wheel? Get an IR temperature gun and do some measurements.
Curious...how long do you keep your tires that you are worried about sidewall cracking/rotting? My tires are in the California heat and sun and I have never had a hint of cracking when I replace my tires at the recommended 5 year interval.Like I said before - in my opinion - to say tire protectant and wax provides nothing at all is just a crazy thing to say.
