help I have a 470 closed sys that is running about 220 -230 .I have put in a new impeller,flushed coolent sys pulled the cover off the water pump and the impeller looks good and is turning with motor is turned over,cleaned out the heat exchanger,back flushed lake water side of coolent, compession tested the cyl at 125 psi,pressured tested the coolent sys to 25psi for one hour,no leak ,replaced the stat and it is still running hot,took the exhaust elbow off it is clear checked the flapper and it was ok.
running out of things to look at . dose anyone have a clue to what is going on.i am at a loss
